I have a Motorguide W75 Saltwater 60" 24 Volt (White) 970200096 Trolling motor. I can't get it to turn left or right. When you try, it makes a jolt like it's going to turn but nothing happens. Propeller operates normal. PLEASE HELP!!
Make sure the collar that you set the depth with is tight and the shaft is seated all the way down in the transmission assembly. If that's not it then there is probably a problem with the transmission assembly and I do not believe that is serviceable.
