Bronlonius
- Oct 21, 2012
- 145
I recently bought a used, but almost new cannon speed n temp, it's similar to the newer cannon intellitroll or the depth raider.
It's incredibly useful for finding the thermocline, the temperature updates very quickly, but I've noticed that the depth reading is not very accurate. Does anyone have any experience with these, is there a way to calibrate them? I realize these are supposed to compensate for blowback, but as an example... even when not moving at all, my depth finder sees the downrigger weight at 50 feet, while the speed n temp sees it at only 44 feet. I trust my depth finder's reading, because if I drop the weight and hit the bottom, i can see that happening on my readout.
It included a spool of coated downrigger line, which the manual says is required for 100 feet or deeper depths, so I'm wondering if even though it works with the uncoated line, if it will be more accurate if I swap out my downrigger cable. I'm not sure how it calculates depth, if it's by pressure I don't think the cable should have anything to do with it but maybe I'm wrong?
