My boat has two batteries and a switch where I can use either battery separately or together. I am not sure if they are the same age but I have been using them separately but alternating between the two each time I use the boat in case they don't have the same capacity to hold a charge. Is this a good idea or not necessary and I should just use them together?
Depending on your answer, I am wondering if I should get a battery tender for each battery for winter storage, if there is one tender that does two separate batteries, or if I should switch to use both batteries and use one battery tender? Thanks
Chris
Chris
