81 Checkmate
- Jul 20, 2010
- 1,360
1981 Checkmate.......898 wiring harness...pre BPA wiring code.
After restoring the boat and putting in rebuilt motor....350 in place of 305. Got it fired up yesterday...all good exept the trim gauge and the fuel gauge both peg.
Fuel gauge reads full....tank was empty and put in 3.5 gallons, could be a bad gauge...if you tap on it...it will jump down.
Trim gauge reads full up.........dont have trim rams hooked up...so transom bell houseing is in a loose position.
Not sure if i have the sender wires hooked up right.......I have orange/brown under dash coming from gauge to a little block thats mounted at the harness plug bracket.......then the two wires both black from the sender going to the same little block.
I have the schematic for the wiring......but its hard to make out how/what the sender wires hook up.
Thanks.
Thanks.
