Shallowman
- Oct 11, 2010
- 114
Ok got most of the right fuses for everything else done . Iam going to use the setup found on the site here to do the bow and stern light http://forums.iboats.com/electrical...s-tracker-v17-re-installing-wires-506306.html
Iam using Led type for both lights , what size fuse should i use on the fuse block for it ? from the picture id go from fuse block to the center post of the switch , and the 2 center posts are jumped correct ?
Iam also considering doing this to the 2 led lights inside the boat aswell , any reason not to ?
