Jchandler5008
- Aug 4, 2013
- 2
My step-father recently purchased a used Play-Craft Pontoon with a 90 hp Mercury 2 stroke outboard. We have had a fish/ski boat for years so I'm somewhat familiar with boats but I have very little experience with wiring them. The wiring on the Pontoon needs overhauled (in my opinion). It looks like someone wired it with spare parts from their garage after finishing a case (or two) of beer. I searched through the forums and have gone through several wiring diagrams for Pontoon boats with two batteries. I have a diagram drawn out for this pontoon but I have several questions about the components.
1. The boat came with two deep cell batteries that had sat for awhile. One was located in the rear compartment adjacent to the motor and the other was 'jimmy rigged' behind the captain's chair. Both were dead on arrival however i was able to charge them enough to start the motor, operate the trim/fishfinder/stereo/lights. The starter battery was wired to a fuse block (see picture) and from what I can tell powers the starter/trim/gauges. Battery #2 was wired to a switch panel that is seperate from the fuse block, that operates the fishfinder/stereo/lights/CB. I took both batteries to AutoZone to have them charged and luckily for me they accidentally sent them out with the deposit truck.. So I now have two brand new deep cell RV/Marine Batteries. My question is should one of the batteries say "Starter" on it or is it okay that they are both 12V deep cell marine batteries?
2. I plan on building a small shelf in the rear compartment to hold both batteries up off of the floor and in place. I would like to replace the ancient fuse panel in the console. Does anyone have suggestions as far as what kind of fuse block or panel would be appropriate for this type of application? Is there one that is made to connect two two batteries?
3. I plan to wire one battery to the starter/gauges/nav lights and then be able to switch to the "house" battery for the accessories. I've seen several diagrams on how to do this and all of them are a bit different. Has anyone done this and if so can you please describe what/how you did it and the results?
4. I've read several conflicting posts about the motors ability to recharge one or both batteries. I have included a picture of the motor (Merc 90 hp 2 stroke). If anyone knows anything about the recharge capabilities of this motor and could give me some information I would greatly appreciate it. From what I've read, it is best to have the motor wired to the starting battery only because wiring to the starter and house can cause problems with recharging. Again any info would be great.
5. And my last question (for now) is in regards to types/gauges of wire to be used. What I've read suggests 10 gauge wire from the battery to the fuse block however I haven't found anything from the fuse block to the accessories.
Thank you in advance, sorry this is so long. Trying to avoid several different posts and give a good description.
