Re: Bilge Pump Automatic Float Switch Bilge Pump Installation Help
No. Here is the way I would recommend: battery + => fuse => float switch => tap into existing power line from dash switch
This sets up a separate power path through the float switch, which is always energized unless you remove the fuse. No problem with forgetting to flip the switch to the proper position to ensure automatic operation say, while you leave the boat unattended. The current manual switch on the dash will continue to operate as usual. Fleetwin is suggesting the same setup.
EDIT: If you're going to leave the boat unattended for any length of time, an automatic resetting circuit breaker might be a better bet instead of a fuse on the float switch circuit.
