yesim Looking To Replace 11 Existing Tovgle Switches With Light Up Tip Switches. The Box Says 20A At 12V. Is This The Max Load The Contacts Can Handle At 12V?
Not sure what that has to do with replacing switches.I Dont Want To Unnecessarily Drain My Battery, Should I Be Concerned?
That's odd. Are they supposed to be that way or did you reverse the line and load connections?They Are Light Up Tip Switches, The switch Lights Are Continually IlluminateD Even If The Switch IS In The Off position
