I think my livewell pump is out on my 2006 Alumacraft 175, not sure where it is located so I can replace it. Does anyone no where it is located, and the easiest way to replace it?
The livewell pump is often mounted with the intake through the transom. But you should be able to find it by following the hose that fills the livewell.
