Replacing my navigation lights?
hostage
Is there anything I should note or think about when replacing a light fixture on a boat? I would like to move to LEDs and the current housing got cracked some how. I am going to measure the spots where my lights are now to see if it will fit. my current housing has two screws, this one looks like it has 1 on top: Attwood 1nm LED Stainless Steel Sidelights - iboats
I am thinking of using marine-tex to seal up the old screw holes. Then use splicers to connect the wires followed by shrink wrap, then liquid electric tape. I am thinking that the lights will come with some gaskets on the bottom to prevent wanter from entering the hull. If not I guess I can use 5200. I am worried that the current lights might be leaking into the cuddy.
-Hostage
UncleWillie
Re: Replacing my navigation lights?
Sounds like a Plan to me!
Make sure you get the correct light for the Boat size.
Some need 1nm, some need 2nm.
hostage
It is for a 19ft boat. The current light reads Percko A-16
boaterinsd
is that in all states? the 1 nm and 2 nm specs?
jhebert
Ensign
The lights required to be shown by a power-driven vessel when underway are given in the federal regulations. Check with your individual state to see if they have promulgated any additional rules about lighting a power-driven vessel when underway. I doubt they have, as these regulations are typically harmonized across all states.
The federal regulations are very simple to read and are the best source of an authoritative answer to any question about vessel lighting. See
Navigation Rules Online
http://www.navcen.uscg.gov/index.php?pageName=Rule23
Visibility requirements are given in
For more details on lights, see the technical annex of the rules:
eCFR — Code of Federal Regulations
Also, you will not be replacing your lights. You will be replacing your lamps. The light is what is seen by other vessels, and this should not change. You are just changing the lamps that produce the light.
hostage
Hrmm...so it looks like all I need is a 1nm. My current one is Perko Bi-Color, Chrome Plated, Zinc Alloy Bow Light - 262950, Boat Lighting at Sportsman's Guide
Note: I have two of them and they both have a black insert to block off the light for each respective side. The current size is: 3 1/4 x 2 5/16 x 5/8".
I am looking at two sets of lights:
Attwood 2nm Stainless Steel Bow Sidelights - iboats
3 3/8 x 2 7/16 x 1 1/2
and
3 x 2.3 x 1.3
one has 2nm other has 1nm. They are about $8 difference, I do have a recess on the boat that is slightly ~1/16" bigger than the current lamps. I am worried that the 2nm will be a little to big.
Thanks in advance,
Hostage
JoLin
No need to overthink this, hostage. You have a 19' boat. The 1nm lights meet regs, the 2nm lights are the 'belt plus suspenders' choice if the additional safety factor appeals to you.
My .02
hostage
My .02
More worry about the 2nm fitting and I worry about the quality of the 1nm. If I go with the 2nm I am worried it would over hang a bit leaving a gap under the light as the light as the bow dips down.
hostage
I went ahead and go the 1nm ones, I would rather have it fit.
Thanks for the info and help!
