How to ground a minn kota trolling motor and its battery on a fiberglass boat?
WyldFya
How can I ground my battery and motor on a fiberglass boat? The only metal on the boat is a small 3/8" steel rim that goes around the boat. There is no good way to attach a wire to the rim either.
Any suggestions greatly appreciated.
WyldFya
Re: How to ground a minn kota trolling motor and its battery on a fiberglass boat?
Also, I have a 55# thrust Minn kota, and the last two times I have gone out fishing, the charge has only lasted 20-30 minutes. This is after giving a full charge. Could this be due to the lack of grounding, or is it something else? I have taken the boat out 5 times. The first 3 times I had no problems, and ran the motor for 3-5 hours each time. The last two times the charge has only lasted 20-30 minutes.
scottmm73
What type of battery are you using? Sounds to me like you are not using deep cycle battery.
GA_Boater
You don't ground the battery or the TM to the boat. Glass or aluminum, you always connect the TM ground and positive to the battery. Either directly or using a high amperage connector.
colbyt
Master Chief Petty Officer
How old is the battery? Are the cells full of distilled water? How has it been stored? How soon after use was it charged? Was the charge maintained?
Depending on the answers a one year old battery may be all done.
WyldFya
It is a deep cycle trolling battery.
WyldFya
That is what I thought, but the local outdoor sporting shop told me to always ground the battery, and trolling motor.
WyldFya
The battery is 4 years old. I do not know if it was maintained with a charge or not, up until the last couple weeks, where it has always had a full charge, while not in use. There was one night where I did not charge the battery until the following morning. I have not checked to see if the cells are full of distilled water.
NYBo
I would be suspicious of any advice these people give you. :eek:
Barnacle_Bill
They don't know what they are talking about. Have your battery load tested.
colbyt
4-5 years on a deep cycle battery is a fairly typical life if very well maintained. To confirm, charge it fully and take it to a shop for a test. I suspect a weak or dead cell.
GA_Boater
That's why they are are sporting goods shop and not a boat dealer. :facepalm:
Fudoshin
yeah the negative on the batteries is all the ground you need, like you said already I have a tri hull and finding a ground location is like finding a leprechaun unless you'd attach to any navigation switches you may have, but your normal hook up is all you need.
WyldFya
Took the boat out again today, with a brand new battery, and same problem. So now I'm sure it has to do with the motor. I'm assuming a have a short somewhere in the motor. How difficult is it to fix a problem of this nature, or what other problems could cause this?
nite fisherman
My unprofessional opinion is sounds like the seal in the tm is letting water into the motor housing and that is what is draining your battery so quickly. Water getting in there is causing the short.
WyldFya
I checked the motor housing, and it was full of water. I suspected a short, but did not think of water causing that. When taking the housing apart, I noticed there was a missing washer, and that the outer chamber wall for the housing was installed backwards.
I got everything dried out, reassembled, and tested it out, in the shop. It ran it for 30 minutes non-stop, full speed, with no sign of lost speed. Looks like I'll need to order some parts.
Silvertip
Running a troller for that long out of the water is not a good idea since water is used for cooling.
Grub54891
The shop said they should be grounded, mabe they meant bonded? 2 different things.
Grub
ajax5240
Grounding the battery to fiberglass would be like using your spare tire as the trailer ground. Just doesn't make sense, but it gives others a good laugh. I wonder if the guys at your local store there ground an electrical outlet in their house to the nearest 2x4 stud?
