I just recently purchased a 13' aluminum boat that came with a 15 hp Johnson (with electric start). I would like to also be able to use a 46# Minn Kota (42 amp draw at full power) transom mount trolling motor, which on a occasion I may result to just using it only. I need help choosing a battery that will "best" fit my needs. I am aware that the bigger the group, the more run time. I am looking at the Walmart Deep Cycle batteries (24, 27 & 29 group) & the questions I have are 1. would I be better off with a true Deep Cycle battery, or should I get the dual-purpose starting battery?? I will occasionally use the battery to start the Johnson, but most use will come from the Minn Kota trolling motor. 2. To help distribute weight on the boat, I want to move the battery up to the bow of the boat. I would need approximately 12', & would I use 6 or 4 gauge wire?? 3. As a refresher, can sombody tell me where I would put the in-line fuse on the cable from the battery & motor?? Do I install it on the positive or negative wire?? Any other information is greatly appreciated.
