Motorguide 109 # "Clicking Sound"
Shemp
Hello,
First timer here. I have a 7 year old digital 109# motorguide. When it runs it makes a clicking sound even with the prop off. This occurs at any speed. There is no evidence of any foreign material around the shaft. I was told by a motorguide service guy that the brushes need to be changed. I did this and $160 later no change.
Any ideas on what it could be? The motor also doesn't seem to be thrusting 109 lbs. Is there a way to check this also?
Thank you in advance for any help.
Shemp
Silvertip
Re: Motorguide 109 # "Clicking Sound"
Does the clicking frequency change with motor speed or does it stay constant regardless what speed the motor is running? I take it the noise is INSIDE the motor housing?
Shemp
Yes the sound changes as the motor speeds up or slows down
