juicegoose
- Mar 30, 2013
- 105
I appreciate the patience and responses.
I recently bought a 16' alweld boat. It has several power points(perko connector, 12v outlets) throughout the boat. I'm also running 2 batteries(starting, trolling), fish finder.
1. Trolling motor - should it be on it's own battery with nothing else connected?
2. How should all the grounds connect. My thought was to take all the grounds from the front of the boat to a common bus then bring one wire back to the battery. Do i connect the blacks of both batteries together?
3. If the motor is connected to the battery and i have both battery negatives and the system negatives connected to the same terminal is that a correct ground path?
4. my trolling motor is a 46lb motorguide that has #8 ran from the battery to the plug. Currently it has an inline 30amp fuse. I'm thinking i need to put in a 50a resettable but am not 100% sure. Your thoughts?
5. Any special considerations on the fishfinder? I've heard about noise issues but am not sure the path to take to isolate them.
Thanks again.
Thanks again.
