Re: Fish Finders and Boat Speed
Hey Guys,
I just bought a new garmin 150 fish finder. I was wondering how fast i could drive my boat while having the stern mounted transducer in the water.
Cheers,
Ryan
If you mount it correctly you should be able to run at normal speed with the transducer attached. If the transducer is not mounted right you can end up with a fountain spray from the transducer when the boat is moving quickly.
Depending on how the transducer is mounted and the local water flow you may find that the fishfinder will not detect anything or show noise from water turbulence when moving at speed. When you slow down the fishfinder operation will improve.
When I was mounting my depth finder transducer (basically the same a a fishfinder transducer) I got a suction cup mount (portable mount) from the transducer manufacturer that let me test the transducer position and mounting angle in the water and at various speeds for best operation before drilling holes in the transom.
