Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
wiring diagram for Sun Tracker Ship/shore Electrical Breaker box
  • wiring diagram for Sun Tracker Ship/shore Electrical Breaker box
    Hello, I have a 92 Sun Tracker 32ft party hut that has an electrial problem in the breaker box. I removed the cover and found that several wires have come loose. Tracker Marine sent me schematics for everything except for this box. Does anyone have a wiring diagram for this box. For example the coiled pigtail for the ground fault breaker goes to the polarity switch - does this make sense? This box is under the sink and has: Shore/off/ Generator switch, polarity switch with a light, ground fault breaker and individual breakers with outlets for appliance plugs. Thanks, Terry
    Re: wiring diagram for Sun Tracker Ship/shore Electrical Breaker box
    Post a picture of the box and the wiring (A nice clear picture big enough to see) someone may be able to see the problem.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      There are rules about netrual connetions between shore power and generator power (single point of neutral and ground connection) so the ground fault breaker neutral going to a switch might not be as odd as you think. Diagrams and pictures will help as well as explaining what the problem you are having is. Not being rude or condescending shore/generator power should not be played with unless you have a good understanding of the system and the rules.
      • #4
        Thanks for the suggestion, I will post a picture when I get home... gone for a few days. Terry
        • #5
          I will diagram what I have when I get back to the boat and I will take pictures. When the neutral confused a local electrician I decided to seek help on this forum. These Sun Tracker Party huts were made for many years so I was hoping that someone had a wiring diagram, or schematic of the switch box but this is proving to be difficult. Many of these boats manufactured in the 90's look very similar so I assumed they had the same switch box.
          I will try to educate myself on the basics of shore power/ generator wiring re ground and neutral from a safety standpoint. Aluminum boat, water, electricity... I appreciate your caution. I will not modify anything without qualified help. Thank you
          • #6
            Here is one good link for your education folder.
            http://www.uscgboating.org/assets/pd...ELECTRICAL.pdf
            Don S.
            • #7
              Thanks, downloaded and reading.....
              Back to Top
