the camper
- Nov 6, 2012
- 1
Transom mount TD bracket broke while 20 miles offshore. I had no way of securing or fixing the issue at the time. On the way home, the TD removed itself from the wire. Unfortunate transom damage as well as the TD was banging around by the wire for a few hours until it finally broke off. The head unit started showing some crazy temps while it was banging around. Temp up to 170 degrees F. Fishing in 68-70 degree water. Finally stopped showing temp and any sonar signal. Looked back to find out the TD was gone. Why do they make these brackets out of cheap plastic? I tried to plead my case to Humminbird without avail. Purchased a new TD. This time I opted to go with an in hull angled shoot through (Deadrise is 17 degrees). Had to buy a seperate temp probe. Ran all the wires and got her all set to test and my head unit is still reading 160 plus degrees with the new probe. I called Humminbird again and they say my head unit is probably damaged because of the TD seperation and being run on the way home from fishing withought a TD attached. How is this possible. Once again I tried to plead my case that it was the plastic TD that was the original problem. No luck. They offered to fix it for 180 dollars. I am already out 80 for the TD and temp probe. So, my question is: has anybody heard that running a severed TD cable would cause damage to my Humminbird 787 2ci head unit? Will a software update help?. Is there a way to do a "reset" on the unit? Any help would be appreciated. Nothing but trouble with this unit so far. Now out of warranty. Aughhhh. I just want to go fishing.
Regards,
Terry
Regards,
Terry
