Need Help Wiring Boat
boatbeginner1
I just bought a Starcraft Jet Star 15'. Currently it is completly gutted.
Anyway, I need help with the wiring big time! Is there any material that I can read/look at so learn more? Any help appriceated!
I have a battery that needs to be attatched to a switch panel, that has Bow Light, Stern Light, Couresty Light, Bilge Pump
Thanks!
boatbeginner1
Re: Need Help Wiring Boat
I am ordering the book. Is there another link tht I can used hile waiting for the book to come in?
The sticky notes I have looked at however; they are not what I needed.
Don S
Here is a general diagram of an outboard, an ON/Off battery switch, fuse for the power going to the front of the boat, and wiring going to the helm fuse panel.
From that fuse panel you would add your individual circuits.
attachment.php
You can add resetable circuit breakers instead of the 20A fuse, use larger wiring for more amperage, better fuse panels, etc. But it gives you a general idea how power gets to the fuse panel at the helm.
Piece715
I am by no means an expert and this was my first wiring job. Take you time and research.. ask all the questions u need... I had never worked with electrical systems before and was able to completely wire my boat from scratch... Here is the diagram I made. Again there are prob errors but I followed this when installing and haven't had any trouble to this day... Use all good quality materials etc. Hope this helps
Don S
What would really help is if you posted a picture of a switch panel you would like to use. You know what will fit and what you would like to see in there.
Understand also, that your engine, and engine instruments are all separate from the accessories like your lights, pumps, etc.
the bow stern light switch is drawn incorrect stern light will stay on when battery is connected and bow light will work in both running and anchor positions, panel lights stay on until the battery is disconnected, you have both a fuse and a breaker from the battery to the main fuse panel. just minor faults and im sure you correct them on the boat
boatbeginner1
Here is the front view of my current switch panel.
I would like to use something similar however, adding an extra switch.
Im not sure what gauges I will be using. Any ideas of which ones I should or shouldnt?
I will deffinitly have a:
Bow/Stern Light
Bilge Pump
I many have a:
Stereo
Don S
What I was referring to was what panel do YOU want to use, what instruments do YOU want, what accessory items are you planning on buying andinstalling.
We can help you wire up what YOU have chosen, but we aren't the ones choosing the items for you.
boatbeginner1
In looking fir a 4 seitch( nt sure exactly but know I want 4). A fuel gauge ad tachometer. I plan on using a stereo not sure about a VHF.
ok so you have thought about 4 switchs and maybe a radio thats a good start so heres a few things to think about
its a nice boat so do you want to stay with the era or go with the hi-tech look.
basic boats need:
speedo
tach
fuel gauge (if the tank is built in)
volt gauge is nice to have
bilge pump (manual or auto or dual?)
bow and anchor light with the switch for anchor only
some sort of small internal lighting kept low to illuminate the inside of the boat only (used to work anchor and find key switch)
horn (crome fog horns with small air compressor)
additional things
stereo (with or with out amp)
maybe a vhf radio
my thoughts are stainless steel or crome ringed gauges, toggle switchs mounted to brushed stainless plate (home depo has nice plates there used on doors and other things kinda makes shopping fun to find something that will look right for the era), possible cig lighter socket for accessorys in stainless, hidden radio face plate or mounted under dash with blue tooth to a ipod, all electrical hidden under the dash including a nice 8 point fuse holder with built in ground buss, modern breaker near the battery that can also act as a service disconnect if required.........the problem is its not my boat so why dont you tell us what you want and we will help guide you to the right diagram unless you want something off the wall then we will draw a print for you.
boatbeginner1
I would like to go original with a few things modern. I'm thinking stainless steel gauges, steering wheel, and switch pan(is it possible to buy them 4 switch stainless steel?
The stereo would be hidden and if I have a VHF, I'd moun in unde the dash. Is a VHF necessary. I know it's a good thing to have and all. Could I buy it later. Ido t think I need to put stereo and VHF on switcher.
I will be putting lights under the bow, along the sides, and in goin to try to put and in the dash tray( there's a lip I could fit them in)
boatbeginner1
Il will stay near shore but up in the Nothern VA area and then down in nC
NYBo
If you mean you you'll be boating in saltwater near the shore, definitely get a VHF radio. It's a must-have piece of safety equipment for that kind of boating, IMO.
EDIT: I see you have a 15' boat, so I'm thinking you're going to be in protected waters only. For the time being, you could have a handheld VHF aboard.
boatbeginner1
I will get a handheld VHF radio at first than maybe later il upgrade to a mounted one.
boatbeginner1
Where can I purchase a Switch Panel that has 4 switches, one that is up-middle(off)-down for Nav Lights?
