Re: need a sticky/link on how to use a basic volt meter
Agreed -- if one does not know WHY you check resistance, WHY you check voltage, WHY you check current, WHEN it is appropriate to do these tests, or what the terms even mean, then knowing how to use the meter is of no value. Instructions normally come with the meter. But -- the long and short of this is:
VOLTAGE: A boat has a 12 volt DC electrical system. You set the meter to read DC volts and measure ACROSS the +12 volt and ground leads to verify a device or circuit has power applied to it. Trolling motors can have 12 volt, 24 volt, or 36 volt battery banks consisting of one, two or three 12 volt batteries in SERIES as applicable (example: 12 x 3 = 36 and 12 x 2 = 24). If you don't know the difference between parallel and series wiring then you should understand why knowing how to work the meter is of little or no value.
RESISTANCE: Resistance in a circuit is measured in OHMs. You set the meter to read RESISTANCE (Rx1, Rx10, Rx100, etc). You NEVER measure resistance on a powered circuit unless you want to fry the meter. The meter has it's own internal battery for resistance measuring purposes. You measure resistance of a fuel sending unit, temperature sender, trim sender, coils, and other devices. The resistance setting is also used to verify end-to-end "continuity" of a circuit. Unless you know what value to expect (listed in the product literature or service manuals) you have no idea what is OK and not OK. You must also disconnect the circuit under test from anything else to ensure you are measuring ONLY the device of interest.
CURRENT: The current (amps) flowing in a circuit is measured with the AMPS function. On most handheld meters current is limited to about 10 amps so you don't use that function to test starter current draw. Current is measured with the meter in SERIES with the circuit under test. You need to know the "expected" current draw in that circuit to conclude whether or not the value you are reading is OK or not OK.
Some winter day when it about 30 below zero I will create a pictorial of how these three measurements are made using real parts.
