Hello,
Fellows I need some help with the wiring on my livewell pumpout pump and recirc. I went fishing on Friday and caught some red drum threw them in the livewell came home to turn on the livewell pumpout and nothing happened. The trouble shooting steps i took was.
I noticed that the rest of my pumps were working. So I leaned under the dash of my bass boat and fiddled with the wires. The rocker stitch light was on but the pump was not working not even humming or anything. I checked the fuses they were not blown. I was stumbed so I went to the transom and traced the wires and noticed that the connections were badly corroded so I clipped both ends of the wires the ones from the rocker switch and the ones to my pump and spliced them together. I turned my switch back on and the wires became hot and started smoking, so I turned it back off. I got a idea and used a known good switch my bilge pump wires and switch. I connected it to my livewell pumpout pump and this time it blew my fuse in the circuit box. I replaced the fuse and hooked my bilge pump back up and now it dont work either. I dont know what to do now any advise!
Phillip
Phillip
