DUMB Volt meter question
torombolo
Afternoon everyone, I have a very dumb newbie question here. I have a 2001 Monterey 262 with a dual battery set up. The boat is marina kept conetec to the shore power. My question is what should the volt meter on the helm read when themotor is on? I notice it is always fluctuating between 10 & 13 Volts. Is this the normal range, shoud it be higher?
As you can see I'm 500% knowledge depraved on the electrical dept. LOL
Thanks in advance for your help!!
Lyle29464
Re: DUMB Volt meter question
With the battery charger off and your key on you should read about 12 volts. when you start the boat it should jump into the 14 volt range. ( 1200 RPM or so) with the boat off and the shore power on that meter should read about 13.
torombolo
Checked this weekend and never got over 12.5 does that mean something is wrong?
bruceb58
That is too low. Just to make sure, use a handhel multimeter at the battery itself to make sure it isn't your gauge. If it also reads 12.5V, your alternator needs to be repaired.
