billyjoe46
- Feb 26, 2011
- 4
BACKGROUND: I am about to be the owner of a 2001 Chris Craft 26' Constellation which has an electrical problem with the Equipment Switch Panel. The "dashboard" mounted Equipment Switch Panel has about 8 or 9 switches for Navigation Lights, Manual Bilge Pumps, Cockpit Lights, etc. Apparently these switches are connected to a remote circuit board in the engine compartment which is "burned out" and is no longer stocked by Chris Craft as a spare part. I guess the original system had the Equipment Panel Switches activating relays in the circuit board rather than the actual devices themselves.
Frankly, I would just like to eliminate the need for this problematic circuit board by adding a new "fuse block" or "breaker panel" and hard wiring the various devices to new switches.
THE QUESTION: Has anyone out there done this kind of fix on a Chris Craft Constellation? If so, do you have a wiring diagram of how you hooked it up. The trickiest part to me is how to wire the bilge pumps so they work automatically from the float switch and also from the Manual switch.
ALTERNATE: Does anyone have a wiring diagram for how to install a "fuse block" and connect lighting circuits and bilge pumps to their respective switches - then perhaps I could just clone that technique into this Chris Craft application.
Thanks in advance for any advice the Forum can provide!
