LattimerII
- Aug 14, 2011
- 16
I posted a week or so ago about Blue Sea Add a battery and ultimately plan on installing that system in the winter. Right now it is insanely hot outside, and I think the perko switch (which was quick to install) will accomplish what I really want for the time being. Mainly I want to be able to play music with engine off and save battery #1.
Questions:
1. The deep cycle I bought is a group 29 and the cranking battery I already had is group 24. Both are standard wet cell types. Is this an issue with the size difference? I don't think it will be, but I dont want to be wrong and burn the boat to the waterline either!
2. I have a simple Attwood marine/ATV trickle charger that supposedly is water resistant and won't overcharge batteries. Can I simply add it to positive and negative on either battery and set switch to both to charge? Again I think that I can, but just double checking.
Searched forum, and I think that the answer to 2 is yes from what others have said.
Here is a crude drawing of my setup
Questions:
