deedgrabber
- Jul 12, 2012
- 2
I want to hook up an inverter to power my AC outlets when I'm away from shore and I don't want to invest in an expensive unit with transfer switch, etc.
Is there any reason I couldn't just disconnect the shore power AC from the AC outlet breaker, and permanently attach an inverter from the battery to this breaker?
When I'm on shore, the 30A battery charger will power the battery which will power the inverter/AC outlets. And at sea I will get the AC power I want.
I'm sure it's not that efficient to run AC power from shore to the battery back to the inverter again but what would the harm be? Little or no power is used from the AC outlets when at shore anyway.
I'm trying to avoid having some kind of manual switch and frying the inverter.
