Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Help! Minn Kota 55 won't run
  • Help! Minn Kota 55 won't run
    Newbie here.
    I have a Minn Kota Endura 55. Recently the motor stopped working intermittently. After some troubleshooting I replaced the switch. That did not fix it. I found it works when out of the water but not when put in the water. I now suspect a bad seal and water getting into the motor housing. Does this sound right> If so, where can I find instructions on taking the housing apart? What should I look for once inside?
    Thanks!
    Re: Help! Minn Kota 55 won't run
    Check all your battery connections. They must be clean and tight. What size wire are you using between the battery and motor? Do you have a 50 amp breaker installed? If that is all good look at this. http://tnhatlfs01.thenethouse.com/st...r%20Manual.pdf
    "A manual is a cheap investment"
    Fair Winds and Following Seas
    Bill
    PTC USN ret
    • #3
      Thanks for the reply but you may be thinking of a different motor. I'm using an Endura 55. The wires are connected to the motor. No circuit breaker. If I use my backup motor--an Endura 35--it works fine.
      • #4
        Trying again:
        I have a Minn Kota Endura 55. Recently the motor stopped working intermittently. After some troubleshooting I replaced the switch. That did not fix it. I found it works when out of the water but not when put in the water. I now suspect a bad seal and water getting into the motor housing. Does this sound right?
        So how do I take the housing apart? Where do I get a new seal? What should I check once inside?
        Thanks.
        Back to Top
