Re: Vhf issues... Is it likely the antenna?
Unscrew the antenna plug from the radio and pull it away so that the center pin is still making contact but the outer part of the connector is not touching the radio. If you can't hear another radio transmitting (and breaking squelch) from 8' (or way further for that matter) away, you have a radio problem. As far as having to have an FCC license to service the radio, that only applies if you are adjusting/servicing circuits that affect the transmitted signal. Not that your going to be able to service it anyway without having the required knowledge/experience in troubleshooting/servicing marine electronic equipment but you could for example, replace a bad speaker, power switch, display...etc. without an FCC license.
When you receive with the radio unsquelched, is it full quieting (loud and clear with no noise)? If so, the radio likely has a fault in the squelch circuitry. If the received signal is "in the noise" it's likely a bad RF amplifier. Either one will require servicing by an experienced tech. BTW, that noise you hear with the radio unsquelched is not static, it's receiver noise generated almost entirely within the receiver circuitry.
Eric
Experienced FCC licensed service tech
