in to deep
- Nov 6, 2009
- 62
Just got a new alternator and it only has a single post.
my 1979 omc stern drive system has a 3 wire for the old alternator!
the new alternator has a built in regulator!
so my question is ( if i get it wrong please correct but be kind as its a ego thing)
with the new alternator i can do away with the old regulator mounted on the thermostat houseing!
then the just attach the charging wire to the battery terminal on the starter ! ?
then that will charge both battery's from the dual battery switch when it is in the both battery's position??
did i get this right????
In Too Deep ?? Go All The Way !!
