Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
Wiring problem on my Bayliner Capri 1700
  • Wiring problem on my Bayliner Capri 1700
    Hi guys!
    I bought an Bayliner Capri and Im following some guides in the forum to put the boat ready to go in the water.
    Last night I decided to remove the ignition because there were rust problems and sometimes it gets stuck.
    What did I do? Marked all the color wires in the ignition with a permanent marker; Red/White R/W and so on, but when I clean and oil it, the marks went off ;(!!! :face palm:
    Does any one Help me please?
    Many thanks!
    Re: Wiring problem on my Bayliner Capri 1700
    Welcome to iboats!
    A 1700 is an outboard boat. My 1988 wiring diagram doesn't list any R/W wire to the ignition switch. It shows the following 5 terminals on the switch, which are labelled with letters:
    M: white from motor (magneto) + white from lanyard kill switch
    B: red (12 gauge)
    C: green (choke)
    S: yellow (starter solenoid)
    M: blue (magneto ground) + other white from lanyard kill switch
    Bob, Seneca Lake NY
    '88 Bayliner 1700 Capri bowrider, 85 HP Force O/B, "Sea Weasel"
    '94 Grumman Fish'N Fun pontoon, 40 HP Merc
    Want a vessel safety check? Click here. Want to join the Coast Guard Auxiliary? Click here.
    Disclaimer: Although I am a member of the USCG Auxiliary, the opinions and advice in my replies are my own and do not necessarily reflect CG or CG Auxiliary policy or regulations unless so specified.
    • #3
      R/W was an example, but all most wires have stripes, excluding de Black
      I will check "NYBo", many many thanks!!
      • #4
        What year is your boat? If it has a Force outboard, I may have other diagrams that better match what you have.
        Bob, Seneca Lake NY
        • #5
          Mine is a 93 Bayliner Capri 1700 with a Force 70Hp Engine.
          I think it as 7 pins, I remember 2 in the center (choke I think) 3+2 in the side.
          • #6
            Checked the wiring and your scheme helped a lot! Ive got 6 wires a I followed the wires in order to put it in correct order.
            Now I have another problem, boat wont shut down when I turn key off (???)
            The only way is remove the power cut!
            • #7
              The motor is shut down by the switch connecting the two magneto wires, so those are the ones you need to check.
              Bob, Seneca Lake NY
