I have a 1994 Sea Pro 17ft v-hull and I Want to replace the front bow light. I can't seem to locate the old wires. Any tips on how to get the new wires from the front to the center console?
If you are lucky there will be a tube for the wires, in this case tie a small plastic bag to a strong string and vacuum is through the tube then tie and tape the wire to it and pull it back trough. If there is no tube, you can use a fish tape (made of fiberglass or steel on a reel found at hardware store) just feed it from where you are to where you want to go in the boat, lots of fun, good luck.
