I have a 95 sylvan pro select dc. In the bow control panel it has a 4 prong receptacle plug for a trolling motor plug. The top right terminal is the positive from the front battery in the boat, top left is the negative. The bottom right terminal is the positve from the back battery, the bottom left is the negative. I have a 24 volt minn kota maxxum. Doea anyone know what terminals I would use to pull 24 volts. Or do I need to split the positive wire from the trolling motor into two to connect to both positves then run one negative. Does anyone know where I can get a diagram for this standard plug receptacle. I hear they are common accessories in higher level fishing boats. Thanks for the help
