scbasschaser
- Dec 7, 2011
- 30
I have a 25merc electric start outboard w/o an alternator or internal charging system on an older jon boat. My electronics are powered by a stand alone 12v deep cycle interstate marine battery that I recharge after each use. I run a depth finder, trolling motor and lights and occasional cigarette lighter accessory off this main battery. Mercury said I could use a standard volt meter and watch as the gauge go down in volts to determine how much charge my accessories are using and would like an indash mount for looks. They are sending me the part and the wiring diagram (I hope) but would like some input if this is the best route for a simple look of what my battery is doing after several hours on the water.
Also, I don't disconnect when not in use and since I have power switches for each device I confused about why undo you battery wiring each time. Sounds like overkill to me? I have several things wired to my battery and can't undo them each time.
