I was thinking about putting a lewmar pro-sport 550 windlass on my boat. I have a dual battery setup already but my engine is a Mercury 125 and the charging system only puts out 18amps. In the product specs it says 150w ( 150w\12v= 12.5a). But then it says Current draw at working load: 35a. If a device draws more current than the charging system can put out will I end up frying a regulator, stator, or other device involved with charging system or will the extra current just be provided by the batteries?
Spec for Windlass.
http://www.lewmar.com/assets/img/dataset/Manual_ProSport-65001242.pdf
Mercury 125 Mod#1125422zy Ser#0T509164
Thanks in advance for advice.
Spec for Windlass.
