Re: How to replace the fuel sensor on a 21 foot 2003 Seaswirl with a 2003 200 hp Yama
Have you actually diagnosed the sender as faulty? If you have, then the next step is to gain access to it. The senders are very generic and as long as the mounting holes are the same, length is all you need to be concerned about. Some senders are adjustable for length. You can get your new sender right here on iBoats. You disconnect the battery, disconnect the wires at the sender (mark them or take a photo), remove the mounting screws and pull the sender from the tank. Reverse the procedure to install the new one.
