Re: Is there such thing as a VHF/FM combo antenna?
The name of the game is bandwidth of the antenna. From an AM point of view, (to me), any old wire stuck up in the air will pull in that band. FM at 88-108 and VHF right above it are close enough that the BW of the antenna may be wide enough for your power to be fairly flat. Whip antennas are very broad banded and omni-directional.
If your incoming signal strength is well above the S/N of your receiver, the antenna loss at that frequency could be well below optimum and you would still get adequate reception.
As said, get the antenna that is cut for the freq that is most important to you and the rest will have to ride it out........buttttt it's not necessarily as bad as one might expect.
Good Luck,
Mark
