Re: Windshield wiper?!
You fuse the line, not the device. You need an appropriately sized fuse at each power source to protect the wire between the fuse and the device.
Typically, you have one heavy wire running up to the helm to a distribution panel that is fused via a circuit breaker back by the battery. The power to the various devices is then distributed to the various devices from the distribution panel. Each connection coming off the distribution panel is then fused to suit the device in use.
