I have a Teleflex Voltmeter gauge, in my 1986 Wellcraft Nova II, that doesn't work. It sits at about 12v with the key off and jumps to over 18, needle buried, when the key is turned on. It's like it needs to be adjusted. Voltage at the gauge connection has been verified to be 12.x volts, so it isn't my electrical system. The gauge for the other engine functions fine. I have not actually removed the gauge from the dash panel, and I see no external way to adjust it. I have seen some gauges that can be adjusted, but this one doesn't look like it's possible, and I hesitate to dissect it without more knowledge.
Has anyone else ever fixed/adjusted one of these gauges?
I hate to try and replace it because I have not seen any current Teleflex gauges that match this face.
It is part number 3552.
Thanks,
Chris
Thanks,
Chris
