I have a Larson Senza 206. I have a Faria Multi-function Tachometer. My tach is not working. When I turn the ignition switch, it doesn't jump, so I assume it's not getting power. The picture is of a wire that is attached to the power terminal. Already attached to the power terminal is a purple wire (power) so I'm not sure what this wire does. Right now this wire is not attached to anything else but the tach. I assume this is my problem. Does anyone know what this should plug into?
thanks,
Phil
