Re: Sea Era wireing
with reguards to your question about wiring your gps and wire routs, there is usually on most boats a tube that runs beneth the deck near your fuseblock to the rear of the boat or where ever your battery is at. The wires can also be run through the side of the boat. Look for that fuseblock and find the main powerwires I was talking about in my previous post and they will lead you the route of the wires going aft to your battery. I'm going to assume the gps you want to use is a combo unit with gps and fish/depth finder. The main unit will mount near the drivers station wherever you want to put it. It will have a set of power wires, red is the hot wire, black is the ground. The unit will have it's own internal on/off switch so all you need to do is run the ground (black) wire to the fuseblock ground section or sepperate ground strip as the case may be. Than run the hot (red) wire to the positive connection on your fuse block. Allot of these units have a built in, in-line fuse on the hot wire or maybe an internal fuse in the main unit. Irreguardless I recomend running the hot wire to a spot on the fuseblock that has a fuse. Now that you have done this, your main unit will have power. Now I'm assuming you will have to mount a transducer to your transom. Follow the mfg instructions with reguards to location and how to mount it. As far as running the transducer wire, you can run it the route the other wires take from the rear of your boat forwards or you may find an alternate route to run it. Either way you want to make sure it's out of harms way and won't get steped on or damaged. Once you've run it, simply plug it into the recepticle on your main unit. If you're going to try to run it under the deck, you will probibly need to get whats known as a fish tape. This is basicaly a stiff wile on a roll that you can feed along the underdeck route, than connect a wire to and than pull it back feeding the wire thru the route. Most hardware stors carry these. Also when working with electricity, please disconnect your battery while working so as not to accidently cause a short or shock yourself.
Art
