Tried to call around and figure out where to get used (older) Baja parts to no avail after about five #s. It looks like my bow lights are out and the green lens is gone/destroyed. I'm not sure how to replace the assembly and what to replace it. Can someone give me some guidance? I don't mind using aftermarket Attwood or the like.
Boat is 1999 Baja Boss 272. Assembly is of the type that houses both red and green lights.
Updated 05/02: Direct replacement purchased and installed (Perko) but keeps blowing the 10A fuse. All other electrical components work fine. Install method described below, is there a way to isolate the issue?
