Re: Marine Glue for fishfinder transducer mounting on transom
Sure ... but, if this is your 1st install, I would do it with a temporary adhesive (say, ordinary silicon) until you are satisfied with the location and the performance you get. You don't need to use starboard, there are any number of plastic materials that you can use (polypropylene comes to mind) as your "screw into" mounting plate. Using the supplied screws, mount your transducer bracket onto your custom made plate and glue it onto the transom with the silicon seal or similar removable product. Once you're happy with the location, peel it off, clean the area, and use 5200 for a permanent attachment. Too many people screw their transducers onto their transom, only to later realize they've picked a bad spot ... moving it around several times until their transom looks like swiss cheese. Then they come on here and ask what's the best product to seal up all the holes thy've made. Go figure.
