Re: VHF Antenna Replacement
Great that we get both sides here as that is what this site is about.
Ok if I was going to buy the 5206 I would not get the 5206-N.
The N means it has a Nylon mounting Ferrule. The Nylon mount if your boat stays in the sun without a cover does not last long before the sun drys it out and it cracks an falls over board hanging by the coax.
Instead get the 5206-C which is Chrome-plated brass ferrule with standard 1"-14 thread. It Cost less than a dollar more.
5206 is An economical and lightweight, self-supporting antenna for good communications where Range is not the Predominant Factor.
It has a Quality copper cable elements for good range and efficiency.
This means it has some tuned Copper COAX for the Main Radiator Element. This is the type I seen most problems with the antenna it self, But then again I talking Pacific Ocean where 8 to 9 foot Swells 8 seconds apart are common all summer long. Plus winds of 25 knots and a Flexable Antenna that flexes lile a wet noodle all day long. Also want to talk VSWR ratios. Put your meter on it and you will find out the SWR changes a lot when the antenna is bent. Also then the radition pattern changes alot. It is no longer horziontal one second it transimiting to airplanes and the next it is submarines. Coax runs are short but it use higher loss Lower Quality RG58 Coax.
This may be fine for slow boats an sheltered inland lakes. The 5206 has a 2 year warranty. Price $30.
Shakespeare Galaxy Style 5225-XP
8' VHF 6dB Gain
Collinear-phased 5/8 wave elements
For the toughest of the tough jobs, Shakespeare introduces the extra edge of silver plated elements on world-renowned, world class, Galaxy marine VHF antennas. The new 5225-XP is a maximum range antenna built in a Shakespeare extra tough fiberglass radome. It's designed to withstand the wind forces and high speeds when used on hard tops, T-tops, and radar arches. The silver plating adds extended performance for extra reliable communications. The antenna's legendary Galaxy? high-gloss finish assures that it's welcome aboard.
Copper and silver plated brass elements for extraordinary range and efficiency
Stainless steel ferrule with standard 1"-14 thread
20' RG-8/X Low-Loss cable plus a PL-259 connector
Suggested mount: Shakespeare 4187
Shakespeare Limited Warranty: 5 YEARS
Silver Plated Elements Extended Performance
This antenna is $121 but it will perform better especily when conditions get bad and you need to be heard.
I consider this a very important saftey iteam on my list but if I was only and inland boater where it is very unlikely you will encounter Life threating conditions it may not be worth it.
http://www.iboats.com/Marine-VHF-Antennas/dm/*******.646659923--**********.174535642--view_id.248106
