Firewalker688
- Mar 26, 2011
- 30
Hello all,
First of all, I have been lurking around here for some time and this site is probably the most comprehensive of any boating site I have ever seen. Thanks to the many who contribute to it. This is my first post so I hope this area is appropriate for the question.
My project is a 1984 bass tracker III with a Mercury 50hp outboard. I decided to replace the decks and I have gutted the entire boat. The wiring under the console is a rats nest of in line fuses and splices and home style wire nuts. It had exposed wires running along the starboard rail to the front casting deck and to be honest I like wiring jobs to look very clean or be hidden completely. The wires described above have been exposed to sunlight for so long they are very faded and I am sure the insulation has degraded over time although they still carry current.
I have used the multi meter to test the integrity of the OE bow mounted tilt trim trailer switch and found it to be defective. It looks like this:
http://cgi.ebay.com/ebaymotors/VINT...4841596QQptZBoatQ5fPartsQ5fAccessoriesQ5fGear
I have given some thought to finding another and I have located a two button switch which I assume is tilt trim only. The OE switch was capable of the "trailer" function which was a LOT quicker in raising the motor than trim up. Perhaps this is the "Tilt"? Forgive me if this is not the correct terminology.
The purpose of having this switch is to rapidly raise the motor after tightening the winch straps while still at the bow to enable me to get off the ramp as soon as possible and let the other boaters get on with it too.
Info about current wires: Red- Hot, Green with white stripe- Down, Blue with white stripe- Up, Purple with white stripe=? The PTT motor is currently not working which really makes me wonder what this wire is supposed to do. This has really made it difficult to re wire this boat. If I trace it to the PTT motor it connects to the three wire plug back there. Is the purple for the "Trailer" portion of lifting?
Questions:
1. What does the purple wire do? Rapid lifting of motor?
2. Ever hear of someone installing a switch to the bow to only function for quick lifting. I don't need to use this switch for fine trim adjustments.
Like this?
http://www.dhcampingandfishingsupply.com/20220.html
3. How does the trailer switch lift so much quicker than the trim up? More voltage? Different gearing or speed the motor turns? I just don't get it.
4. If I get a simple two button tilt trim can it just be wired with the up going to the tilt instead of the trim up?
I am sorry if this question has been beaten to death. I have used the search function that yielded what seems like 14 pages of threads but not really what I am looking for. If it's been covered a link is very appreciated.
On a side note, I am taking pics along the way if anyone is interested in seeing this project unfold I will share. I hope everyone is doing well.
Thanks for any input.
Scott
Questions:
Like this?
Scott
