Re: installing dc charger for 24 v trolling motor on 20 ft pontoon boat
As I would like to keep the cable intact from the charger to the the starter battery this will require me to open up the charger and install a 17 foot 12 AWG x 3 conductor cable
Don't open up the charger and make any modifications inside, this will automatically void your warranty. From what I remember of MinnKota's instructions (AC charger, not DC charger), any modification to the wiring will void the warranty and if cables need to be extended you need to use their cable extension kits. What do the instructions say about lengthening the DC charger cables? My AC charger said specifically NOT TO lengthen the output cables (there are temp sensors in the cable ends) and that you need to use their cable extention kits,,, but I lengthened 1 of the output cables anyway
If there are no warnings against lengthening the engine side of the DC charger, go for it! Don't open up the electronics housing, just add to the existing input cable.
I don't have or have never installed a MK DC charger, but I'm curious;
- what are you installing this on
- what type of engine/alternator is going to be supplying the power to the charger
- is the output sufficient to charge up your TM batteries while motoring around
I looked into one of these, but for what I do it wouldn't work well. The DC charger's output is too small for a heavily depleted battery. it would take hours, and hours, and hours of running the main engine to recharge the TM batteries. If I was on/off a bow mount TM and running and gunning to/from spots it probably would work fine.
That DC charger is limited to a capacity of 10 amps/bank so it's not going to charge up heavily depleted batteries
