I have never had a trolling motor but I have a Minn Kota coming in for my tin boat.
I also went with the 60 amp circuit breaker which is also coming in.
But I have read here somewhere that it's not a good idea to leave the motor connected to the battery for long periods of time indicating that the motor will continue to use power even though it's not being used?
That being said, do you use some type of switch between the motor and the positive lead or are you just disconnecting the lead from the battery when the motor is not in use?
