zonaman
- Apr 1, 2005
- 118
Need some advice wiring an auto bilge switch (refer to attached diagram). The Attwood folks have the brown wire (E) going to the on/off switch (C) on the bilge pump side and the red wire (D) going to the on/off switch on the fuse/power side. That's about 13 feet for each color wire to connect just as the diagram shows. What I would like to know is if I can splice the auto bilge switch into 1. the brown wire any where between the pump and the bilge side of the on/off switch and 2. connect the red wire anywhere between the on/off switch and the fuse?. It would save me several feet of wire if I can.
One more thing, my fuse is longer than the 72" recommended from the battery, it's more like 120" though I'm using 14 awg wire.
Thanks.
Thanks.
