Does anyone know where I can get the correct prop for this trolling motor. The motor has "Pow'r Prop" and "23 lb Thrust" stickers on it. It has 2 switches, 1 for Hi,Med,Lo and 1 for Forward, Off, Reverse. It also has 1 White rocker switch that is for Light on/off. It has the 3" dia. motor with a 5/16" shaft with pin hole. I ordered a prop but it wasn't for the 3" motor and filled down and around the motor side of the prop cone until it doesn't touch against the back of the motor and the pin can now go thru. It looks good, fits tight and spins freely with no rubbing. Will this be OK or will a Sigma 25 or 30 prop work?
