pbolden
- Dec 12, 2009
- 184
Hello Everyone,
I went to install a fixed mount vhf radio. The tight quarters under the helm made it very difficult to locate a hot wire amongst the jumble of wiring. The radio will be mounted under the dash below the stereo system (see pic with red box below). Should I pull the stereo forward and and tie into the stereo's hot wire? Any suggestions would be GREATLY helpful.
The second question is about mounting the antenna. The arrows in the pic below shows where I want to mount it. My concern is that because of the tightness under the helm I might not be able to reach the underside of the mount to attach lock nuts. Any ideas?
As always...much thanks,
Paul Bolden
Paul Bolden
