Hello:
Boat: 1997 Wellcraft Eclipse 240SC
Engine: 1996 Volvo Penta 5.7GLi DP; Model No PLKDCE
Fuel Delivery System; Low Pressure Fuel Pump and Throttle Body Injection (TBI)
Problem: Fuel pump does not activate when ignition switch is turned on.
Troubleshoot:
1) Battery Voltage; 12V confirmed
2)Disconnect fuel pump connector wiring (yellow/w-blue stripe, and black), ignition switch on; no voltage confirmed.
3) Check voltage at fuel pump circuit breaker w/ ignition switch on; 12v confirmed.
4) Remove fuel pump diodes and check voltage at terminals w/ ignition switch on; 12v confirmed at the two perpendicular terminals (don't know what the terminal nos. are but the wires are yellow and red respectively). Cleaned oxidation off diode terminal blades and plugged diodes back in.
5) Checked voltage at alternator connections (Mando 12v, 65 amp model) w/ ignition switch on and w/ voltmeter black lead connected to ground (black wire) terminal; Orange terminal: 12v confirmed; Purple/White terminal, 10.3v confirmed, Purple/White jumper terminal, 10.3v confirmed.
6) Volt meter at dashboard instrument panel reads 10+ volts.
Engine cranks strong, but does not start or fire. No audible sound of fuel pump energizing when ignition switch is turned on prior to rotating switch to the start position.
Can anyone help me with this problem?
Thanks,
RCL
Troubleshoot:
Thanks,
RCL
