ashlo108
- May 30, 2010
- 4
Just bought a pontoon boat and the tranducer is mounted on the back of the transom right by the lower end of the motor. Problem is that above idle speed I lose depth and bottom display, I figured out that it is cavitating because of the water turbulance. I was thinking about mounting it farther up the transom under the deck and in front of the motor. Will this work? Is there less turbulance at that location than at the rear of the boat? Thanks in advanced for any help!!!
