tunnelengineer
- Mar 12, 2006
- 12
Have a Tahoe Q4. I want to replace the crappy audiotronics head unit with a new Sony unit. Here's the deal:
The standard wiring in the boat is 2 speakers, a black ground, and a yellow/red wire (single wire) running to a translucent harness plug. The audiotronics head unit then used a harness to connect factory wiring to the head unit. To install the new Sony unit I spliced the sony harness to the audiotronics harness wires. Ran the red power lead to the red wire on the old wiring harness. The sony head unit did not power on. Noticed it also had a yellow wire to run a non-switched power lead from the battery, so ran another wire from the battery and tied into the yellow wire on the sony harness. Still no power. I'm lost as to what else I need to do to get this unit powering on. Confused as the factory wire is a red/yellow mix wire.
Do you think splicing into the wires of the last harness is the problem? I plug the old harness into the old head unit and it still powers up fine, so I know the red cable is getting juice.
Also confused as the new head unit has an "illumination" orange wire. After the unit not powering up I tried also splicing that orange wire onto the old harness red wire.
The head unit is a Sony CDX-M60ui if it helps.
